phase in bandpass
Seems alot of you don't know what I mean. Ha. Anyway. Everytime I run -12 db slopes. I switch phase on both midranges. doing it to just throws the acoustic phases wayyy out of wack. I've never had to flip just one.
Do you really believe that your amp/processor/HU/passive crossover is actually giving you out-of-phase outputs for mids and tweeters? Like you just stumbled onto something that the engineers overlooked?
starting to sound like it's easier to wait and see what results you get before hassling with the multitude of factors that can change what phase you're getting.
so let me change my question to something more applicable to the real world, what's the most accurate and painless method of determining a speakers phase in a system with multiple speakers and complex crossover networks?
The whole point of that DIYMA discussion I linked earlier was about phase change from crossovers. It gets pretty interesting, with Andy W at one point mentioning a phase EQ that was developed at Harman, but the results weren't audible(horrible paraphrasing). I suggest at minimum to skim the thread and focus on Andy Wehmeyer's responses. There is some real gold to find.
indeed, that was a great read. however, I still feel a little unsure about whether passive and active crossovers (including amplifiers with a -12db LR2 crossover) include an inherent phase modifier in the design. In addition to that, if you have a passive component set HPF'd on the amp and also a seperate passive crossover (for example a 60hz passive is crossed 100hz on the amp or hu) would this end up adding twice the delay?
What you're talking about is cascading filters, and yes there is a phase shift twice if there are two filters on the same channel. What I take away from that DIYMA thread is crossovers should be used as protective filters to cut power as well as restricting drivers to operate in their optimal acoustical bandwidth. Flat phase is the goal, and -24 dB LR filters makes that easier. That filter is super common with DSPs, but most of us don't have that, so that's why you might need to swap polarity of one driver to address a null. If you measure a null and EQ boosting doesn't bring the null up you are probably measuring cancellation.
So two questions. 1. I understand that having a -12 slope gives you a 180 degree phase. Now I don't understand why flipping your speakers polarity/reversing phase digitally is required. Is the phase only flipped from where the x-over starts? Like say normal phase at 100hz then -12db lpf slope at 101hz. Does the 180 phase change only start at 101hz and up or does it effect the whole freq spectrum the driver plays. ie: 100hz and down as well as up.
2. If an amp has a -12 db crossover. Does it automatically flip its drivers polarity internally to keep them having a "normal" phase
AV: Phase & Polarity: Causes And Effects, Differences, Consequences - Pro Sound Web
Once you understand the basics of polarity and phase(the only way there is phase to measure is if the same signal plays from two or more speakers) and how signals sum acoustically you can begin to understand why it may be necessary to swap polarity on certain speakers.
Inverting polarity affects the entire signal range. In the case of a sine wave the top half flips with the bottom. This inversion happens with music as well.
No, car audio amplifiers do not automatically invert polarity if they have 2nd order filters. That's up to you.
Phase and polarity are not the same thing.
Polarity is a single signal. And affects all frequencies in the same manner.
Phase is the relationship between two different signals. And is different at different frequencies and arrival times.
Crossovers affect the electrical phase causing the voltage or current to lag depending on the type of crossover. Acoustic phase just means the noise is getting to your face at different times.
Ok, ok. I think i was confused. The 80prs gives you phase adjustment for each crossover point. I was thinking the "phase" option was effecting the whole freq band the driver is was playing. It only affects the point of x-over and slope. a -12 db slope will give you a 180 degree phase. In order to correct that so its in phase with the driver its sharing frequencies with, i need to flip the phase of that x-over. assuming the other driver had a -24 slope(almost no phase change), Now if the other driver had a -12db slope as well, id still need to flip that drivers phase as well. This is all complicated to explain in words. pics make it so much bettter. Anyway, i think i understand it.
Don't know if you still need help with this, but I've been having crossover issues and was doing a lot of research and learned a lot. a -12db lpf will shift the phase -90 degrees and the -12db hpf will shift it +90, for a phase difference between the 2 of 180. Each order changes it by 45 degrees PER FILTER but people usually say 90 degrees per order because the lf shifts - and the hp shifts + 45 / order
Had this same problem. I talked to a lot of Hertz dealers and they said with 2nd order crossovers, the manufacturer absolutely takes care of the phase issue, at the crossover. So you wire + to + and - to -... I don't know how it is with other manufacturers, but the ONLY way to tell for sure is by using a phase checker or whatever the thing is called. A good reputable shop will have one. And as for the delay issue, from what I understand, each time the signal passes through a crossover, the phase will be modified, but that isn't "delay" per se. If it passes through 6 separate 2nd order hpf crossovers for instance, each time will add +90 degrees of phase (-90 for lpf), so 540 degrees, but since it's phase and not delay, that's the same thing as a total change of 180 degrees. Every time you get to 360 you start over at 0
Hm then that would make it so two drivers, each with -36db. LPF and HPF at the same frequency. Would then give you...what ending phase???
The Camry
Hey, I Try.
The Camry
Western Oregon
Jakerrr
