WOT
Banned
Basically my math sucks, not only can I not accurately figure out my port area, I cant even be sure Im getting the right volume for my box, as every calculator seems to give me different numbers.
This is what the final box will look like, Ive got the whole thing built minus cutting out the front baffle / port and bracing since I cant do the math.
All box numbers are externals and to edges, using 3/4"
The port is where Im lost, the numbers inside the port, for the angles, are INSIDE number, basically, if you were to draw an imaginary square for the triangle cutouts I have, it would be 15.5" across, each side would 11", but each side where it breaks off form the straight up and down port, each length would be 6.5"
The port is 6" wide, 30.5" tall
I will also have about 86" total (4 braces) of 1X2
Im completely lost on how to figure this out. I need to know my internal box volume, total port area, and how long to make that port to get a 40hz tune.
Im sure Ill have to answer some questions as my drawings probly arent the best.
Have no problem paypalin someone a few dollars to help me out with this. Would love to get it done once it stops raining
THANKS!
THANKS!
