Passive crossover help
Backporch
Nj
I have a 96 BMW that had a bad factory amp. Didn't realize until I replaced just about everything else.
My front speakers are two factory speakers in each door and a woofer in the foot area.I replaced only the foot well speaker with a 6" two way speaker.
I realized that the factory amp separated the signal to the speakers so I picked up two 3way passive crossovers. Sound is OK but very low up front and i need to direct the signal mostly up front using the fade control to balance the volume level between front and back. II guess the passive crossovers are killing the signal and maybe I need a small amp prior to the crossovers?? Any suggestions.
The entire system is relatively low budget pioneer head unit kicker 10" sub w/sound ordinance amp and Kenwood basic speakers throughout. It is a convertible so rear speakers are smaller.
Thanks for any suggestions.
Do you have an aftermarket head unit?
put in a new radio if you don't have one , and get a 4 channel amp to drive the speakers
It will sound decently good with the 10" you have in back
Hi Tymoto21
This is what I have installed:
Pioneer DEH-X6700BT Receiver
Kenwood KFC-1365S 5 1/4 front speakers impedance: 4 ohms
BMW factory mid and tweeter in each door
Kenwood KFC-1065S 4" rear speakers impedance: 4 ohms
Kicker 40CWD82 10" sub
Sound Ordnance™ M-2100
2-channel car amplifier — 75 watts RMS x 2
Would it make sense to boost all four channels front and rear, L+R or just concentrate on a 2 channel amplifier and boost prior to the crossovers?
Specs for the crossover is below.
3-Way Passive Crossover NetworkGold Plated Screw Terminals250 Watts RMS/500 Watts PeakHigh Grade Polymer CapacitorsFerrite and Air Cooled Spools
Woofer Frequency: 20Hz-700Hz
Midrange Frequency: 500Hz-3.5kHz
Tweeter Frequency: 4.5kHz-20kHz12dB
per Octave SlopeEnclosed ABS CabinetQuantity: 1 Piece
Still hoping for a response to the use of a pre crossover two channel amp as a possible solution or whatever would be best practice. The 4 channel amp would still result in animbalance between from and rear output?
Backporch
Backporch
Nj
Backporch
