SOLD Orion Amplifiers and Subwoofers
Can't believe I forgot to put the size.
They are 12", 500w RMS, 1000 peak.
The following specs are from the Orion website:
Fs (free-air resonance, Hz) 26.15
Vas (equivalent compliance, cu. ft.) 2.095
Vas (equivalent compliance, liters) 59.33
Qms (Q, mechanical) 4.66
Qes (Q, electrical) 0.48
Qts (total driver Q) 0.44
Re (DC resistance, ohms) 6.77
Z (nominal impedance, ohms) 2.8
Le (inductance, mh) 2.57
Efficiency (1W @ 1M, dB) 85.32
Xmax (one way linear excursion, in.) 0.67
Xmax (one way linear excursion, mm) 17.19
Pe (continuous power handling, watts) 500
Peak power handling (music, watts) 1000
Mms (total moving mass, grams) 216.26
Cms (mechanical compliance, mm/N) 171.32
Bl (motor strength, Tesla-M) 22.32
Sd (effective radiating area, sq. m.) 0.05
Sd (effective radiating area, sq.in.) 76.88
Frequency range (Hz) 30-2.5k
Energy Bandwidth Product (EBP) 54.23
Model Number P12D4
Mounting hole diameter (inches) 10.95
Mounting depth (inches *) 5.25
Basket diameter (inches) 12.45
Model Number P12D4
Typical sealed enclosure (cu. ft.) 1
SPL sealed enclosure (cu. ft.) 0.7
Low Qtc sealed enclosure (cu. ft.) 2.5
Vented enclosure (cu. ft.) 2
Port tuning frequency (Hz) 40hz
Port diameter (inside, in.) 4
Equivalent square port (in.) 3.54x3.54
Port length (in.) 7.44
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
LuckyPiston13
LuckyPiston13
North Dakota
BallinByNature
