orion amp wiring question
choochooSS
Dont bufu a rabid Walrus
i am looking at an orion 900.2 2 channel amp. i have 2 4 ohm dual voice coil subs. how do i wire this amp to acheive each of these specifications:
2x225@4 ohm
2x450@2 ohm
1x900@4 ohm
keep in mind i have two 4 ohm dual voice coil subs i want to hook up to this
thanx:)
4 ohm mono load
Originally posted by nswartley go to your private messages tab in ur user cp, then in that pulldown menu where it says inbox go to sent messages and delete all of those
Ok good to go , Dahm I swear I had done that alreadu and it was empty , Then I looked again and there were alot in there Thx
WEll without much thought, the 2x450 would be the same as 1x900 but you'd be able to fade the subs to either the left or right...unless you want to do that I suggest you go with 4 ohm bridged as described above. Anyways if you do want to fade the subs, just wire up one channel to each sub, + of amp to positive of voice coil one, - of amp to negative of coil one, then run a wire between the pos and neg of voice coil two. Do this on each sub, and each channel of the amp. I think thats right! Should give you two ohms per channel aka 2x450. Good luck.
doesnt that method make it 2x225 at 4 ohms
i think that if u run the second coil of each sub to its respective channel it will then be wired in parallel thereby making it 2x450 at 2 ohms, right?
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
choochooSS
choochooSS
Kindaiwannapokeya
MikeofTulsa
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
