orion 2500d problem
herecomedaboom3
i am having a problem with one of these amps. i have 2 of them and the one works fine. the problem is that i have 2 alpine type r 15's dual 2 and i have 1 sub to each amp and when i turn the vol. up it looks like one subs moves alot more than the other. i swiched the subs to the other amp and then the one that didn't move as much moved more than the one that moved alot. i think the amp might be bad. any suggestions??
i used y splitters at first then i used the line outs on the amp and still did the same thing. gains are all the way up on both. frequency is the same. i'm just very aggravated at this now i have to get this ready for sbn next week.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
2500D's really dont like to be daisy chainged. use the y adapters with em. i hear that when you daisy chain em...sometimes you get a voltage spike through the rca's...frying the rca inputs.
i've never ran two amps, but don't you have to set them to the same power output? if you just have them both turned up, they might not be putting out the same power to each sub.
herecomedaboom3
herecomedaboom3
Sanford, Fl
zachzchw
