Options comparable to The Mag?
ultimate157
Engineering Student
I would've liked to get a 15" mag, however the coil configuration won't really allow me to, and I can't afford the space or $ for 2.
I've got a lanzar opti 2000D that is rated as the following, although I've heard of the Opti doing 2000w RMS at 0.5ohm.
1 x 700 @ 4 ohms
1 x 1100 @ 2 ohms
1 x 1600 @ 1.3 ohms
1 x 2000 @ ½ ohm (MAX)
Fuse: 6 x 30A
I've got an Eclipse SW8200 right now, and I know you have to substitute SQ for SPL, however I would like to retain as much SQ as possible.
I will be doing a ported closure to specifications of the new woofer (Grand Cherokee = spacious)
What other options am I looking at? Single 15", great SQ, low and loud.
mags are awesome, most definatly. i dont see why you wouldnt be able to run one. your options are 4 ohm or 1 ohm final load. and the amp puts out 1600 or so @ 1 ohm. the mag can handle that with ease.
another good bet is the 05 RE xxx's . got louder than the mag off roughly the same power. super low end monster, great SQ.
either one will handle 1600w @ 1 ohm no problem.
Like George said, there is absolutely no reason you can't run a Mag with that amp. You could go with a Fi Q, I've heard they have great SQ and are very loud as well.
ultimate157
Engineering Student
ultimate157
Worcester, ma
exige
