Optima battery size question HELP!!!
mustbenu
i have a integra and the spot for the battery is small.. they reccomend the optima yellow top model D51R.... CCA 500 AMPS
MCA 625 AMPS
Reserve Capacity: 70 Minutes
this sucks because it only has top mounts and compared to:
yellow top model D34/78..
CCA 750 AMPS
MCA 870 AMPS
Reserve Capacity: 120 minutes
this battery is 2 inches wider but has better specs... i really want the d34/78 but i dont think it will fit...... what should i do,
i dont want to put it in the trunk.
just put the battery on its side and get the D34/78 it will work ive seen it many times.. thats wha i have to do wit my car and optima doesnt even recommend any size battery for my car.. just throw it in there or something.. you might have to do a few modifications but its worth it
If you don't want to downsize and get the 75/25 Optima I'd say get out the trusty Dremmel tool and chop up your battery tray to fit the bigger one.
Or get a bigger battery tray.
YEAH ill make the ***** fit... even if i have to remove the ****** //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
mustbenu
mustbenu
new jersey
azbass
