Help! Total Ampage Draw Question?
hoodkid
Got bang?
I have 2 Tsuamni GXA1000D 1000 watt class d Amps and a KENWOOD KAC-8452 800 4-channel amp. Currently im only running 1 Tsuanmi amp, and is giving me magor dimming problems, I plan on doing to Big 3 this week, but anyways i have the choice of getting these 3 alternators, a 130 amp $80, 150 amp $120, or a 170 amp $200, which one would be preferred? I'm thinking about the 150amp but i'm not sure becuase i don't know how to sum up the total ampage //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif ?
And could someone explain how to use a DMM to set gains in simple terms //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif ?
Amperage will vary, but I would do the highest amperage you can... Upgrade your battery as well, and do the Big Three in no less than 1/0 awg cable.
And as for the gains, take the square root of the product of your total power that you are trying to get from the amplifier (what is it rated at normally) multiplied by the ohm load that you will have the speakers wired to on that amp.
SQRT(RMS x Resistance) = voltage via DMM
Not that complicated...
I'm using a DMM right now to set my gains and i followed the sticky on setting gains but my DMM keeps on reading 3.2-9.2:eyebrow: , and i need to get it at 31, i dont know what i'm doing wrong
Hmm... Do you have the positive and negaitive cables in the correct place on the DMM? Maybe try a different DMM?
Put them on your battery and see if you get a number between ~12-14v, if so then the DMM should be fine. If not then it is the DMM malfunctioning, or you doing something wrong...
hoodkid
Got bang?
hoodkid
detroit
PhatTonyDeMarco
