One large battery or two smaller batteries?
Slobalt
I was thinking about getting a group 31 but I have no idea where i could fit it, so what if I got two smaller ones? any down fall to do this?
I was thinking if I added the cca's from the two smaller ones it would be higher anyway but I'm not sure if thats how it works really.
I like to match batteries not mix
so that said either modify under the hood location to fit something decent size
or get 2 smaller the same size
is budget an issue or money is not the issue
I know with stinger their spp2250 is the same price as getting 2 spp1200
I would do 2 matching smaller 1 in front of each wheel well
My battery is already in the trunk //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif so it would be the same price either way I go and I'm going with deka's
Have you upgraded the alternator? A battery on your power won't do ****.
No I have not but I know it's needed and I will be taking it easy on the charging system till then. Stock alt is 140 amp and I'm on a budget but I'm due for a new battery so that comes first.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
979
Slobalt
Slobalt
East Coast
Slobalt
    May 24, 2024
