Older Laptop RAM question
jco1385
expert jcologist
i just bought a Dell Inspiron 7500 laptop for stupid cheap.
Here are the memory specs:
Code:
Inspiron 7500 Memory Specifications
Standard Memory	64 MB (removable)
Maximum Memory	512 MB
Memory Expansion	2 sockets
Memory Comments	PC100 SDRAM SODIMMs
CPU Type	Intel PIII OR Celeron
Model Comments	100MHz FSB
ok.... 64mb stock RAM //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
then i found this:
http://pensacola.craigslist.org/sys/949681031.html
2 --512mb laptop memory chips 4200 ( 1GB total )
will that work with this laptop?
the motherboard may not support all that ram
it says 512 is the cap soooo just run that much? you will see a marked improvement either way, even if you went up to 256 but sheeit dump 512 in there and enjoy the ride //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
so even if it's cap is 512 and i put 1gb it couldn't run it as 512?
or it's just the wrong shit anyway?
It might not boot or it will only see the max. My guess is it might not boot. 2 256s is the ONLY way to go.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
64mb ftmfgdl
first off, you'll most-likely be running windows 98 on that thing, or a stripped down linux. that laptop will only support either pc100 or pc133 ram(rather old, hard to find) in my experience, a desktop that old will not boot w/ more then 512 megs of ram on average. -- hope that helps
jco1385
expert jcologist
jco1385
Mobile, AL
TurdFergueson2
