Old School Sub?
  • Thread starter bocajoe
  • Replies 0
  • Views 642
bocajoe
CarAudio.com Newbie
I have a single old school SoundStream Davinci DV-10 sub/enclosure I would like to run. I know back in the day SoundStream made some decent quality stuff.
It is a Dual Voice Coil 1000w RMS @ 2 ohms. I'm a little older and don't need that much so I am thinking to rewire the DVC to 4 ohms which should make it 500w RMS @ 4 ohms and run an amp with around 500w RMS @ 4 ohms.
SPECS:
DUG™ (DUal Gauze field magnet technology)
DOV™ (Dual Opposing Voice coils technology)
HVA™ (Horizontal and Vertical Alignment Conex spider assembly)
Cast Aluminum 5-piece Basket
Diamond cut finish
Collar-Lock aluminum mounting ring
Multi-Vent back plate
Non-pressed paper cone w/MD6 coating
Large foam rubber, high excursion surround
Gold screw terminals
Dual 2 ohm voice coils
BAEISV hybrid voice coil former
Wood packing crate with chrome hardware
• Frequency Response 29 Hz-1.6 KHz
• 320 Oz. Magnet
• 3" Voice Coil
• Sensitivity 86 dB
• 13mm XMAX
• 1000 Watts RMS
Enclosure recommended from SoundStream: .75 TO 1.0 CUBIC FT. OF AIR SPACE AND A ROUND PORT OF 3in IN DIA. AND 10in IN LENGHT.
Here are the pics (poor things been sitting for years). The enclosure without the speaker is super heavy and seems to be made really well with 4 angled supports on all corners.
What do you guys think of the sub?
bocajoe
CarAudio.com Newbie
bocajoe
Boca Raton, FL
bocajoe
