Completed BNIB Rockford Fosgate Old School System: P4004, P3001, & P3 Sub $1250 total
Brandon Cotton
CarAudio.com Newbie
Price
$1250
Condition (1 worst - 10 best)
10
West Palm Beach, Florida
All 3 components are factory new - never out of the plastic. $500 each for the amps and $400 for the sub, or all 3 for $1,250. Buyer pays shipping.
IMO these are the most beautiful amps ever made. I designed this system back in 2005 and never got the Corvette they were designed for. With this 12" sub being driven by the monoblock amp you'll want the Punch Controls installed if you plan on driving through residential neighborhoods ;) This system delivers that warm analogue sound not produced by modern amps.
P4004 Specifications:
• 50 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
• 200 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode)
• Variable high-pass/low-pass crossover (40-400 Hz, 12 dB/octave)
• Variable Punch Bass boost (0-18 dB at 45 Hz) with remote
• CEA-2006 compliant
• Tri-way capable (Tri-Way crossover required)
• 8-gauge wiring kit and 60-amp fuse recommended — wiring and hardware not included with amplifier
• MOSFET power supplies and output stages
• MEHSA transfers heat efficiently from the MOSFET devices to the heat sink for high performance
• TOPAZ eliminates ground loop noise
• *****-ANA circuitry keeps preamp signal clean
• NOMAD "intelligent" protection circuitry
• Preamp outputs
• Punch Control Included
Dimensions: 16-7/16"W x 2-3/4"H x 11-1/4"D
P3001 Specifications:
• 2-ohm stable mono subwoofer car amplifier
• 150 watts RMS x 1 at 4 ohms
• 300 watts RMS x 1 at 2 ohms
• 900 watts maximum power output
• Variable low- and high-pass filters
• Variable Punch Bass boost with wired remote (0-18 dB at 45 Hz)
• MOSFET power supply and output stages
• MEHSA mounting transfers heat efficiently from the MOSFET devices to
• TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
• Fuse rating 40A x 1
Dimensions:
11-3/4"W x 2-7/16"H x 11-3/16"D
P3 Specifications:
Diameter : 12 Inch
Low Frequency Response : 20 Hz
High Frequency Response : 200 Hz
Sensitivity : 87 dB
Impedance : 2 Ohm / 4 Ohm / 8 Ohm
RMS Power Range : 500 Watts
Peak Power Handling : 1000 Watts
Number of Voice Coils : Dual.
Stock photos:
Was Photo Included
  1. Yes
Was Note Included
  1. Yes
Brandon Cotton
CarAudio.com Newbie
Brandon Cotton
West Palm Beach
Brandon Cotton
