Old School Restoration Install Questions
I have done many restorations and i sure as he ll will not cut anything.
In this vehicle mount it like in previous post under the dash or do a under the seat mount.
You can create your own connector to connect straight to the old harness or just wire directly, it is all preference.
I usually remove the fuel tank from the cab in most resto-mods ....it is safer, AND gives room for the BOOM-BOOM ....
And if you are going all out resto-mod. Look into some modern heated/electric/memory buckets on custom made rails. And then do a custom center console with a good high quality 12" sub in it, and mount the amp/s on the rear cab wall .
what sub should I look at? Another question, how would I make the truck rattle proof? I'd rather not pay for it to be done
16pankos
16pankos
South Dakota
16pankos
