ok need opinions--have pics!!
also i can't just attach a couple door pods to the existing door panel---again there is no room and since these have a 3.5" mounting depth my box would stick out from the door almost 5" and thats not an option.
ok, so you cant do kicks because of that magnetic crap? get some led powder, mix it with fiberglass resin, and use that for the mix of resin when you glass your kick panels. that will stop the magnetic interferance.
then you can make some purdy kicks, and upgrade to components //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
but personally dude. i say spend 2 hours and build a small box for them and see how they sound in the middle. itl cost ya like $10~15 and a few fun filled hours of building time.
see for yourself how they sound. and if they sound bad, hook em up to your home reciever //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lol i got a badass home theater set up---paradign or however you spell it--- i'm just gonna take all the equipment out of my car now---just kidding but this is getting discouraging.
um. well. good luck with that...
i would try using a pice of thin wood and build the door off that pice instead of cutting your doors apart. then just make a wood frame for the arm and speaker baffles and all stuff (use the origional door panel as a template) on that, and then start blobbling on the kittyhair to smooth everything out.
dont cut your doorpanels up though. go to the junkyard and find a car whos panels you like, and cut them up and mix and match parts to attach to your monster door panels..
good luck.
i'm tellin you sell um and get a powered SUB!!! i had the same problem in my caddy, my dad didn't want anything in his trunk because he used it alot so i installed them under the seat THEY SOUND GOOD!
dude i have major bass in my trunk---i just want to fill in some mid bass up front.
alright said screw the jl 6w0's and instead i'm gonna put the memphis studio series co-ax's in the door.
here's the start of it.
well jesus dude =) that was quick =P
x2 //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Good luck with the buildup //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
thanx for the encouragement guys //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif and thanx to gauntlet for the pics in the sticky
bonesninja
bonesninja
Lima, Ohio
bonesninja
