wiring 99 taurus
i have a taurus and im running 4 gauge wire to the trunk and i dont know how to get it through the fire wall from the engin compartment any ideas on how to get it through
drill a hole.
i just installed a deck in one of these (same car) the other day, and it was a PAIN in the *** to get the faceplate off and switch all the knobs to the aftermarket one, and get it all plugged in.
wtf //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
there is usually a grommet on the passanger side somewhere, if not try and find a spot where there is only metal on the otherside and drill a hole.
we didnt install the amps yet, so i havnt done this, but when i installed my amp in my car (1994 cavalier) i just drilled right thru the firewall.
drill+bit+15seconds=hole.
then just snake it thru. not too hard.
Ditto. My 92 Taurus had a grommet (predrilled hole) that put the wire out right between my feet under the dash.
Drill + 15 seconds = hole, then just get rid of all the burrs and you have a smooth hole.
deagle44cmag
deagle44cmag
PA
Raven
