OK... Mustang Custom Box = ?
If you want a custom box in terms of fiberglass, you could build a false floor. Basically you cut a piece of MDF to fit on top of the spare tire, and then use that as the base for the box. Fiberglass from the base along the contours of the wheel well and up to the trunk floor. Build a mounting ring and mount it to the middle of the base (or whereever you want it) with some wooden dowels, and then fiberglass from the mounting out to the edges of where the base meets the trunk floor. Make sure it's air tight and you're good to go.
fr0zenfear
fr0zenfear
az
Gauntlet
