Ok, how well would this 2 amp 2 sub set up work
Afboy143
aka Bumpin Expo
Ok i have 2 4 ohm subs and 2 500 watt mono block amps.
Now what if i did this
I wired the subs like i would with just one mono block amp into 2 ohms. Now i would wire another amp connecting to where the first sub connected to. Would this work well or what? Please help. A pic i made below trys to explain it:D
I really dont think you should do that. What kind of amps are they? If they are stackable (has an RCA input AND output) I'd recommend wiring one sub per amp. Run your RCAs to one amp, then from the RCA OUTS on that amp to the other one. That way you have the full amount from each amp pushing each sub. You'll probably want a distrobution block for your ground and power though.
Afboy143
aka Bumpin Expo
Afboy143
Tampa, Fl
MikeofTulsa
BP1Fanatic
BP1Fanatic
