T travelingtheory 10+ year member Junior Member 11 0 chicago Mar 3, 2002 #1 can any one inform me of the proper formula for calculating Ohms? thanks Click to read more...
U Unregistered Guest Mar 4, 2002 #3 yes, impedence, as in calculating impedence when wiring subs together, such as 3 6ohm dvc or 3 1ohm dvc etc. if u kno the formula email it to me. travelingtheory@aol.com
Phatillusion 5,000+ posts Banned 5,009 272 The XXX Lounge Mar 4, 2002 #4 I think this will help. I'm not 100% sure it's right. Ramos or Zane would be the ones that could definitely give you the correct answer. Anyhow here it is: http://forums.caraudio.com/vb/showthread.php?s=&threadid=2926 In your case you would have to add Sub3 into the equation.
zane 10+ year member Bored..... 1,875 4 Cedar Rapids, IA USA Mar 4, 2002 #5 Ohms law states the following: V=IR R= V/I I = V/R V= Electrical Force in Voltage I = Electrical Current in Amps R= Electrical Resistance in ohms To better explain: http://www.eatel.net/~amptech/elecdisc/ohmslaw.htm For you current situation of 3 DVC woofers- have a look at this: http://www.jlaudio.com/tutorials/wiring/3dvc.html take it easy, -zane
F fu-man-chu 10+ year member Member 129 0 Mar 4, 2002 #6 Another good site is http://www.matrixcaraudio.com/cgi-local/shop.pl/page=index3.html this will tell you how to calculate the formula. good luck
