ohm
it doesent matter as long as you've got enough power, but for the cleanest sound you could take 2 8 ohm's wired in parrellel to give you pretty clean and low sound's, but be sure your amp can supply the power demands in a 4 ohm load
In normal use it won't make a noticeable difference. For low bass ( also called low end extension. Alot depends on the kind of enclosure you put the sub in. What kind of sub(s) are you going to use ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i'm not looking to get new subs, i was just wondering. my friend just got a system with 2 12's in a sealed truck box and a legacy 1600 watt amp. all that his does is make noise. there is not deep bass. all that it does is rattle his trunk. my 2 12" blaupunkts with only 760 watts in sealed truck boxes make really low bass notes and not all of that "noise".
All that 'noise' is probably due to not sound deadening the trunk. It might sound a lot better if he were to deaden some of that unnecessary noise. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
brian
brian
toledo, ohio
gator4thehaters
vegang
vegang
