DarkKnightSM
So again I hear ohm load of a speaker effects sound quality, I get that. On top of that, now a guy is saying a low ohm setup, such as a dual voice 2 wired down to 1 ohm is bad for a sub. Increases likelihood of a burnt voice coil. This make sure No sense if you have a 1 ohm stable amp. Some from what I have read argue that it increases thd or total harmonic distortion. So if i have a more then enough power, say a sub rated at 2000 watt rms, wired to 1 ohm, then an amp rated at 2000 watts rms, i should have zero issues of longevity of the sub or amp, correct?
I know distortion increases heat, which degrades life of unit. But is it really gonna matter at 1 ohm?
Also am having little luck finding evidence online of this guys claims, you guys wanna chime in?
