ummmmmmmm why would it not be safe?? unless he has a single 2 ohm sub and the amp is only 4 ohm stable bridged there won't be any problems. perfectly safe duhummmmm.............. it might work for a while but it doesnt sound safe.... lol parallel it all.
Don't make me get Mel in here... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifummmmm.............. it might work for a while but it doesnt sound safe.... lol parallel it all.
you saying he can run all 4 channels to the sub?? if so i've never tried that beforeYou can bridge the amp so that's it has 2 channels(which would both be stable at 4ohms and probably not much less), then run each bridged channel to the VC of the sub...I assume it a 4ohm SVC sub, right?
What sub/amp are you working with? Are you using the 4 channel purely for the sub, or are you using two of the channel for your dorr speakers as well?
I've done it before with no issues...granted I wasn't driving the amp very hard. You'll basically just have the two channels seeing a 4ohm load since they both go directly to the 4ohm VC, so you'd be safe...I assume.you saying he can run all 4 channels to the sub?? if so i've never tried that before
The sub is a JL Audio 6w3v3, 4 ohm. I just installed a Polk PA500.4 in place of a Lanzar Vibe418, so now it's a spare. I'd like to use the spare Lanzar to power the JL (using all 4 channels) for some very snappy midbass up front. I know the Lanzer specs say 125W RMS x 4 or something but it's probably more like 35W or 40W x 4.
If I bridge the amp to make 2 channels and then connect both of those to the subs voice coil, will that run around 120W RMS x 1 now?
