now whats the problem???
Why So Cereal?
Invisible Cereal
Hooked up my Memphis 1500d today but had no sub to hook it too. Anyway, on my way to class, my highs started distortin at lower levels and eventually just cut off. I cut off the car n cut it back on and they came back on. My first guess is not enough power tto amp but the Memphis has nothing hooked up to it...could it still b pulling that much current??
I have zro gauge wiring with a batcap 800 in trunk and stock 100a alt.
Also you shouldn't have the amp hooked up if you have no woofer on it If you have no where for the power to go to it bad for the amp. Disconnect the remote wire on it until you get your sub
Check and make sure none of your speaker wires are touching. If a positive/negative touch it can make a scratchy distorted sound and can cut the sound out.
But the highs amp was perfect yesterday. Soon as i added the Memphis, problems arose.
But if I restart the car, it works fine. I don't get it
But the highs amp was perfect yesterday. Soon as i added the Memphis, problems arose.But if I restart the car, it works fine. I don't get it
thats what tells me its going into protect... restarting your car will reset the amp, which in turn will reset its protect circuit...
most likely, when you added the second amp, you mis-placed a wire, or ended up with a loose ground... as the second amp wont pull too much amperage without being hooked up to a sub.. it will have alot of potential but not much output
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
Why So Cereal?
