Sold Now Building Boxes
hey.. got a question.. can you build entirely to spec? i just lost my box guy, and need a setup for my new daily driver... a little pickup.. extended cab, but i want it to fit the contours.. hit me up on aol for more.. if your interested..
Can you build me one? I want a picture of Richard Simmons painted on mine.
Box can be painted in florescant pink, or lavendar.
I also want flowers on the sides. Roses, if you can.
Can I have a picture of Steve on it as well?
Please let me know, I need a box for my pack of Funky Pups I bought!!!
I do custom box work too. Build entirely to specs that customer needs. Not trying to steal Ranger's business but people need options //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Ranger, you got any pics of boxes you have built? I like to see other people's boxes they have built. Nice to see other people makin money the same way I do.
Will
Dimensions:
Frame Diameter: 12.5 in. (318 mm)
Mounting Hole Diameter: 10.5 in. (267 mm)
Mounting Depth: 9.5 in. (241 mm)
Overall Depth: 11.25 in. (286 mm)
Magnet Diameter: 7.5 in. (191 mm)
Pole Vent Clearance: 0.75 in. (19 mm)
Displacement: 0.14 cu. ft. (3.03 ltrs)
Enclosure Recommendations:
Sealed Range: 1.25 - 1.625 cu. ft. (35.4 - 46.02 ltrs.)
Recommended Sealed Volume: 1.375 cu. ft. (38.94 ltrs.)
Fc: 44.7 Hz
F3: 40.4 Hz
Qtc: 0.792
Ported Range: 1.5 - 2.25 cu. ft. (42.5 - 63.7 ltrs.)
Recommended Ported Volume: 1.75 cu. ft. (49.56 ltrs)
Recommended Tuning: 32 Hz
Port Type: “Slot” ports are recommended. See Data Sheet for detailed info.
Think you can build a box to the slot-ported specifications on the 12 W7? It would be for a Ford Focus as well, if that makes it any harder :p...and how much $$ for the building..and there's two of them as well..almost forgot to add that...heh
Dimensions:Frame Diameter: 12.5 in. (318 mm)
Fc: 44.7 Hz
F3: 40.4 Hz
Qtc: 0.792
So basically a box for 2 12W7s? I can do it...just need Maximum measurements.
RangerMan
Premium Member
Premium Member
RangerMan
NC
RangerMan
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
