Not getting loud!!!!
Evan3m
two L7s hooked up to a power acoustik 3000db wires to 2 ohm....im not sure why but she isnt getting loud...they hit kinda hard and they play....but nothing like i thought they would....the rubber on the subs arent even moving the way they should....why could this be? ive got 2 gauge wire...the rca is coming from the head unit cause i havnt put the EQ in yet....it might be put into the front or rear output instead of sub though....not sure, cause i didnt plug that in. you think that could be it? does it matter?
ummm...i dont think there is a sub level...you are just able to turn the sub on or off... but i hooked that same rca to my amp for my mids and they played fine....nice and loud...and when i put the bass remote on the amp is was a bit better....but not much
ok cool....when i wire voice coil 1 on the subs together and then run the + and - out of each sub....can i put both of them into the output of the amp? will it still run on 2 ohm?
i found the sub level....it goes up to 15 and it was at 0.....maybe that was y....it hits alot harder and is alot louder now....i put it at 8....should that be good?
and the amp specs says 1800 at 2 ohm....my bad...i was looking at 1 ohm
Evan3m
Evan3m
SXM
AznRevlAzn
