NOOB!!What type of kit do I need to hook up a 4 channel amp and a mono amp?!
Hoyta
I plan on hooking up a 60x4 Alpine and a 200 x 1 Alpine soon in my Sierra.The 4 Channel is going to 2 componet sets in the front and coaxials in the rear. The Mono is going to a single 12" woofer. I would like to order my kit tonight, but I'm not sure what to order. Not really worried about brands as much as what components of the kit I need. I'm pretty sure I'll need a distribution block as well!
Thanks, in advance, for your help!
-Adam
well you need wire id say use 4awg. you need a fuse less than 12" away from battery, distro block and thats about it. make sure you have a good ground and youre all set.
x2 on Knu for wire. Only thing is they only have 1/0 ga. dual amp kit which would be overkill for this install if you don't plan on upgrading. So if you think you might benefit from bigger wire now, go for it. If you're just gonna piece together your own 4 ga. kit, go for it. If not something like this will suit you well.
Just keep in mind that you will likely upgrade. It happens to all of us. But I just thought I'd mention^^^ in case you fall into the small group that doesnt
Hoyta
Hoyta
Edenton,NC
daboyfrumdabx
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
