Wiring 6 speakers...
stilltippin863
how do i wire 6 8ohm speakers to a audiophonics 1500watt 2 channel amp here are the specs... 1 6 inch speaker indrive side and passenger side front doors....4 8's in back dash... if someone will take the time to draw it up i will appreciate it very much!
or just tell me exatly how to wire it detailed thanks alot...
OH YEAH THE SPEAKERS ARE SINGLE COIL SO JUST 1 POS+ AND 1 NEG-
•2 channel [2 ohm] 300w x 4
•2 channel [4 ohm] 200w x 4
•1 channel mono [4 ohm] 600w x 1
•2 ohm load capacity
•Variable low [30-500hz] pass filter
•Variable high [50-1Khz] pass filter
•Subsonic Filter [10Hz - 100Hz]
•Bass boost
•W x L x H: 270 x 358 x 32mm [10 5/8” x 14 1/16” x 11/4”
uh...get another 2 channel or just use 1 4-channel...//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
and if it's a 2-channel you are using why do your specs say x4 lol
but yeah have a 2 channel running the fronts x2 at 8ohm and have another running the rears each pair parallel at 4ohm x2. or get a 4 channel and run the 6's on the front and 8's on the rear channel...how do you have all that goodness in your sig and not know how to wire up 6 speakers?? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
personally i think it's weird you're running 6's up front and four 8's in there rear but to each their own....put em all in the doors, put a 8ohm tweeter in each pillar and run each side at 2 ohmx2 off that amp hehe
lol i woulnt talk TX is bad about stupid crap too...lol...like 50inch rims on a cutlass lol.....but yeah i am not good with ohms at all... and i already found out how to run themm.....1 6inch 2 8's on one side of amp same on other side...
But I'm not the one with big rims on a POS car...you are, however, the one throwing a ton of speakers in a car, including four 8" speakers in the back shelf. It's a FL thing, I understand that you can't help yourself. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'm just fucking with you anyways.
stilltippin863
stilltippin863
Florida
mbrooky
Mike Mccabe
Giles
    Jun 27, 2026
