Noob question about active crossover and amp settings
  • 6
I'm not sure how to answer about airspace. It is big, haha. I have the crossover frequency set to 80hz, that's what he recommended.
I'm not talking about crossover frequency. A crossover is merely a filter that cuts off certain frequencies before it even gets to the speaker. When you're dealing with box specs of a ported box, the port itself has a tuning. For a daily ported box, most are tuned around the 30's range. That means you'll have a nice bump around the tuning frequency. When you calculate airspace, you have to subtract out the displacement of sub, thickness of wood, port, bracing, and anything else that's inside the box. The fact that your box is big, it'll make your sub very efficient(loud) with very little power.
It;s very unlikely that you popped the Pico if you didn't hot swap or short something out. So you might just be yet another victim of plain ol alt whine.
If you ground the RCA's and it gets waaaaay better, it's a good sign that the Pico is gone.
The 80 has a bit of a learning curve, but like anything else, once you learn it you can fly through the menus.
Are you in network mode? High or Lo output?
It's 2.5 net @35hz
So ground the RCAs again and call it a day, really no need to swap out the HU.
Yeah I just grounded them, 100% eliminated the alternator whine. I definitely blew the pico fuse. It's really frustrating though because I didn't even hot swap the rcas. It's just that one of them was very loose and actually came unplugged then touched it again and there it went. Really lame those things are SO sensitive. I'm just going to say screw it and assume it won't hurt anything else.
You should be good to go.
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
jwark
jwark
Pflugerville, TX
fly_marlin
