no sound from woofers
drummergrrl
Ok here's the deal. I have two JBL 10" in my car that I'm not getting anything out. I'm getting sound out everywhere else. I''m getting power to my amp and I've even tried a different amp and it didn't work either. I've taken out the woofers and hooked them up inside and they work fine. I tried hooking another up to the output at the head and nothing came out . So is it possible that it's a problem at output of the head unit?? I've tried several different things ... anyone have an idea?? thanks
jamie
how can the ground affect the output of the amp?
cuz i have the same prob, n it's none of the wiring. i replaced the RCAs, checked everything, amp is gettin power, but no signal going out to subs. i checked with another sub, n zip. i m gonna try hookin subs to another amp, or replacin amp. but does ground really affect teh output?
Ah, sorry. I didn't see that she said she had power to the amp. Make sure it's a good connection and there is little or no voltage drop from the battery when the engine is off. If you get power, and you have a good ground then there are 3 things that could be wrong. Remote wire, RCA's, or the amplifier itself. Remote wire carries current, so you can check that w/ a DMM. Same w/ RCA's. If it's neither, then try replacement with a friends amp.
Originally posted by drummergrrl Ok here's the deal. I have two JBL 10" in my car that I'm not getting anything out. I'm getting sound out everywhere else. I''m getting power to my amp and I've even tried a different amp and it didn't work either. I've taken out the woofers and hooked them up inside and they work fine. I tried hooking another up to the output at the head and nothing came out . So is it possible that it's a problem at output of the head unit?? I've tried several different things ... anyone have an idea?? thanks
jamie
i fixed my problem with the amp, it was just the fuse that's by the battery so that's good.
r u sure u gettin power to ur amp? while the amp is "on", take te + power off the amp, cuz the amp might just be "on" but from the remote wire, it's not really turned on tho. so check the fuse u got nothing to lose.
"taken out the woofers n hooked them up inside"? what u mean inside? if u hooked them to another amp n they work, then that's good, it aint the subs.
either way, this is what i did to see what the problem was:
1. check fuses from battery n from amp. good place to start.
2. make sure all the connections r fine.
3. plug another sub that works for sure (borrow one from a friend) into ur output of amp, if dont' work then it's not the subs.
4. try pluggin someone else's amp into ur setup, n hook ur JBL subs, if still not then...
5. try replacing the RCAs n see if that aint it.
6. if u still haven't fixed ur problem, then it aint the wires, nor the power, nor the amp, nor the sub. so it's left to the head unit. n dunno how to check that. but u can't check the subwoofer outputs w a multimeter, i think they need to open it up, or do some tests on it.
good luck
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Marine speakers would be Ideal as stated and Coax. Polks would work very well. First choice of mine would be...
484
drummergrrl
drummergrrl
OKC, OK
Matador
    May 31, 2024
    May 24, 2024
