Originally posted by drummergrrl Ok here's the deal. I have two JBL 10" in my car that I'm not getting anything out. I'm getting sound out everywhere else. I''m getting power to my amp and I've even tried a different amp and it didn't work either. I've taken out the woofers and hooked them up inside and they work fine. I tried hooking another up to the output at the head and nothing came out . So is it possible that it's a problem at output of the head unit?? I've tried several different things ... anyone have an idea?? thanks
jamie
i fixed my problem with the amp, it was just the fuse that's by the battery so that's good.
r u sure u gettin power to ur amp? while the amp is "on", take te + power off the amp, cuz the amp might just be "on" but from the remote wire, it's not really turned on tho. so check the fuse u got nothing to lose.
"taken out the woofers n hooked them up inside"? what u mean inside? if u hooked them to another amp n they work, then that's good, it aint the subs.
either way, this is what i did to see what the problem was:
1. check fuses from battery n from amp. good place to start.
2. make sure all the connections r fine.
3. plug another sub that works for sure (borrow one from a friend) into ur output of amp, if dont' work then it's not the subs.
4. try pluggin someone else's amp into ur setup, n hook ur JBL subs, if still not then...
5. try replacing the RCAs n see if that aint it.
6. if u still haven't fixed ur problem, then it aint the wires, nor the power, nor the amp, nor the sub. so it's left to the head unit. n dunno how to check that. but u can't check the subwoofer outputs w a multimeter, i think they need to open it up, or do some tests on it.
good luck
