No idea where to start in my car.
  • 4
Full Tilt
Bonafide MAFer
2,006
Iowa
Hey, guys. I recently just picked up a set of subs for my Grand Prix and I know that I'm going to be needing to upgrade my front stage to even get close to keeping up with these subs (Tantric HDDs) at full tilt. I likely won't even then.
That being said, I've got a ZED Leviathan that I'm hoping to incorporate into this install. I won't be using all the channels on it, but I want some speakers that are going to pair well with it, and get loud. There's a good chance I'll only put speakers/tweeters up front and attempt to run some mids in the back. Any suggestions on gear?
Also, this particular car came equipped with a Monsoon sound system, which has another speaker in the middle of the front dashboard. Is this a space I should consider using, or just empty it and leave it alone?
Leave the center alone. There are some great components out. But we need a budget to recommend some of these
Jim, just gimme something to spend money on //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
A couple hundred bucks is what I planned on spending for a couple speakers/tweeters themselves, along with some mids. I'm not sticking to a hard budget, just looking for the some good bang-for-buck gear.
I'd go with ampere dream series components. And the matching coaxes
How would they stack up against something like Incriminator's I65C component sets? I've got a set of those laying around, would it be worth buying the Amperes?
How would they stack up against something like Incriminator's I65C component sets? I've got a set of those laying around, would it be worth buying the Amperes?[/quoteGreat. These thing sound really good. And the mid bass is nice I like them as a go to budget set under $240
Are you looking for a deck ? I got a slightly used but mint 80 prs for sale
they are HDDs man. I'd go with some killer PA mids and some decently loud soft domes if you want to go full tilt with your setup. Are you limited to 6.5s or can you go 8 inch?
If you can go 8 inch, out of the 6 channels of the leviathan, i'd bridge 4 of them to the mids alone and put the remaining on the tweets.
Appreciate it, but I'm good on a deck
I guess I'm not necessarily limited, I just figured I'd keep it simple using 6.5s in the doors. I'll have to pull the doors apart to see if I'd have room to run bigger.
Ive seen plenty of these cars with ten inch sub/ subs inverted/facing up and ported to the rear.. even a single 12
601
You have roughly 50 liters total, which will probably work with that sub.
So im getting the design together for the 2 12's for the truck. Its back from the transmission shop and the burnouts are nice.... so we can get...
Full Tilt
Bonafide MAFer
Full Tilt
Iowa
Full Tilt
    May 31, 2024
    May 24, 2024
