Nex gen lithium batteries?
  • 6
Have been searching around the Web for a cost effective lithium option. I came across this nex gen company there whole description makes it sound like it's the best lithium ever but you know how that goes. There prices are some of the best I've seen but have Seen nobody try them in a audio build yet basically I'm asking for you guys input on them. Trying to run a ampere tfe 8.0 at .5 ohm already have a 240 amp alt.
Based on the information you provided, it must be the BEST ever.. Don't know why no one else has jumped on them yet.. It's better than anything else on the market today.. No need to let us investigate them. Just buy it!
You wont know until you test discharge rates/output.
Generally i dont recommend batteries if you can use alts but its better than killing your alt.
Id wait till the prices come down and run a big cap bank
Well I called them yesterday and they said that if there are any issues or your not 100% satisfied they will take it back and give you a refund. So we will probably give it a try in this build I will start a build log where you guys can tune in and see more details on the build.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
344
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
971
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
835
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
67bass71
67bass71
Lake City, FL
67bass71
    May 16, 2024
    May 16, 2024
