Newbie needs advice about JL Audio Amp
killertraylor
Hello. It's probably been 10 years since I've had a really nice car stereo set-up, and I'm ready to take the plunge again. I can't seem to get good advice at local audio shops I've been too, so I thought I'd post a few questions here. I just bought a new clarion head unit (DXZ845MC) with 2 sets of pre-outs and I'd like to purchase the following:
1 JL Audio 300/4 to run 2 pairs of JL Audio XR650-CXI6.5's
1 JL Audio 500/1 to run a single JL Audio 10W6 in a .88 cf sealed enclosure
I'm putting the system in a 2004 Dodge Ram Quad cab pickup - the sub box is a custom box that replaces the middle seat up front (40/20/40) seats up front)
The 6.5's would go in each of the 4 doors. I might also ad a pair of JL Audio TR 350-CX3.5's in the dash and run them off of the head unit.
Does it look like I have enough power for all of the speakers and sub? Are my ohms going to be an issue? Any recommendations to make this system sound better? I'm on a budget of about $1500 and can get all of the JL stuff for about that much from an online vendor. Are the coaxials going to sound o.k. or should I consider components up front? I primarily listen to Country and newer rock music. Thank you in advance for your help.
Power seems fine. Impedences shouldn't be a problem. I would recommend you get some sound deadening for the doors, and seriously consider a component set for upfront.
Honestly, I would probably drop down to a 300/2 for the front, run the rear co-axials off the headunit's internal amp and get a comp set for the front to run off the 300/2. And don't get 3.5's for the dash.
Thanks - that's some great advice. I'm going to go with MB Quart PCE 216's 6.5 comps in the front doors and power them with a 300/2 and run the rear coaxials off the deck. Should I mount the tweeters in the dash where the 3.5" dash speakers are located, or should I put them on the doors relatively close to the 6.5's?
Thanks again!
Joe
Buy some velcro and play around with the tweeter mounting (dash, door, a-pillar, etc) till you find the spot that you think sounds best. Though typically it is better to mount the tweeter near the mid.
killertraylor
killertraylor
Portland, OR
squeak9798
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
