Newbie needing help on system parts.
bs9191
I have an AUDIOPIPE TXX 12", 1600w max, 800rms sub. 2 ohm I'm pretty sure.
At the moment I'm looking for some crisp, silky mids out of it to accommodate both hiphop and the quick double bass kicks of hardcore music. I'm brand new at it so I'm having the hardest time finding what amps would be good for this preference. Let alone what would even be compatible for it.
This would be in the spacy trunk of my Buick.
I know its a dumb post, but **** idk where else to look for help on this. I literally only have the sub and need to know what I need for this system to fit the preferences I've specified. I'll deal with installation after the parts I basically need are aquired.
frustration ;(
Welcome. You need to be sure of the impedance, model number?
Budget for the amp? It should include an amp wiring kit.
Just so you get your terminology correct, mids are vocals and instruments between 200Hz and 4kHz. The sub will play below 80Hz. Mid bass is 80Hz to 200Hz, approximately.
How the sub will sound is determined by the enclosure and orientation.
bs9191
bs9191
Georgia
keep_hope_alive
