newbie help
Buy a distrobution block (like said) one for power wire one for ground wires. Then you run your 2 or 4 gauge (or whatever) to the block and run two 4-8 gauge wires out to the two amps. For the remote on just run a jumper from one amp to the next. And for the signal an RCA jumper from the line out, youll be set bud.
what do you mean a signal an rca jumper from the line out ?
im sorry im a newb =/
Well... you have your RCA lines from your head unit that go into the amp RCA inputs right?
Then you should have another pair of RCA connectors on your amp that say "line out" or "pass through" run these lines into your 2nd amps input rca's
thats all i need to do ? just run it from the other amp ? ****it -_-'' i ordered Y-Adapters
Thats why its there //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Also depending on the amp you might be able to switch it to use only one input, Thats how my rockford works
daicacharco
daicacharco
San Diego. CA
blackbonnie
