New truck, new setup, opinions and info needed amps, speakers etc
  • 6
Fosgate Forever
USSD
Just listed my MRV-F345 and MRD-M1005 for sale and am looking to change up the stereo setup this time around. My (semi)main concern is SQL. The alpine amps were GREAT when it came to sound, but lacked the "make you bleed from your brain" volume I crave when listening to Zeppelin. My previous speakers were fosate fanatic components and the HU was a CDA 7998.
This time around I'd like some input on amps with great SQL but will rock your fillings out when needed. No brand preference, Input on speakers and HU as well wont be bad either (HU must been touch live traffic blah blah blah)
Keeping my old subs so i'll need something with a fair amount of balls to drive them
Type X 12" and a RF Power HX2 15"
Thanks in advance.
well, what i have in right now, is a gen 1 t5001bd. stuck it in just to test, and see what it could do..... puts out 1160wrms @ 1ohm iirc..... sounds real clean doing it to. if you want it real compact, powerfull, and clean, a couple old school amps come to mind right away- memphis 1000d (1100rmsx1) and us amps of the 90's. those both have a nice small footprint, and put out. real clean while doing it, too. i would have any you find serviced by a tech first, to check the caps, and solder joints.
I just decided to keep my old amps. The importance of the new amps is not worth the money I would need to spend to get the ones I would really want. My digital V12s never let me down so I'll spend that money on the stang where its needed.
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
625
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
Fosgate Forever
USSD
Fosgate Forever
Kommiefornia
Fosgate Forever
