New System not as loud as I assumed or see on YouTube
I loved the DD-1, it was simple, and safe. If you know how to use it along with the level you normally listen to its a perfect tool. I get plenty of poutput along with a perfect blend using one. Its nice to listen to something that raises the volume of all amps at the same time.
Seems like it either works really well or really poorly depending on the install. My biggest issue is most people have no idea how to set gains at all, so when the thing doesn't work right, they are basically screwed. It's not foolproof enough to be put into anyones hands.
You do have to have a understanding of how everything works to get the most out of it JUST like a scope. Most people I have seen burn up subs using one set it with the -15db tone and played dirty music. For all we know the OPs SS filter is set at 50hz, that would cause a lack of excursion.
Can you even get 5 cubes in the trunk of a car without building it inside it? The external dimensions are 31.5 wide, 16 high and 19 deep, a single inch in any area would cause it not to fit in the trunk. This box almost wedged. I think I'm limited there and my builder accommodated for that with the best I could get.
Odds are you can fit bigger if you don't go with all right angles in construction of the box. From my testing a 12" in 3 or 3.5 cube is as loud as a 15 and has generally more low extension. I can get more out of a 10 than a 12 up to a little over 3 cube.
I have a single 12" American Bass XFL in a 7.85 cu. ft. box... Nothing anywhere close to the recommended specs by American Bass and this thing absolutely slams. Running off a Hifonics BRX1600.1d amp at 2 ohms so 1200W RMS, kerf ported. Manufacturer specs aren't always the way to go. It was built to the exact fit of the trunk of my car, it can slide in and out with a little fannagling. It is possible to go much bigger than 5 cu. ft. in a car, you just need the right car //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
455
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
888
16
918
b0r
b0r
Richmond
jrdnhsnbrg
    May 16, 2024
    May 16, 2024
