new sub not moving at all
johnwohl
i changed my sub out today for a new re audio se 12 and got nothing. its a 4ohm dvc so i wired the voice coils up for 2 ohms since my amp is 500wrms @ 2 ohm, and confirmed correct at 2ohm with a multimeter.
i then connected the sub to the terminals and verified 2 ohm on the outside terminals. satisfied that I have it connected properly I fired everything up and got nothing but a faint hum from the sub. i verified the sub is getting power. i had the gain turned down a bit but it was still showing about 20v at the terminals. the cone was going nowhere.
any ideas what's wrong here? it's supposedly a new sub. i got it from audio-club on ebay which other people I know have had success with.
turn up the gain?? check all of your setting on your headunit and amp.
the gain is fine, 24v should be around 300w, at least enough to see some movement. low pass is at 120hz, subsonic filter is at 25hz, bass boost is at zero
use a small AAA OR AA battery and touch the wires connected to each coil at a time. the cone will move out if if wired right. then do both coils at the same time to make sure you wire them together right.
Ok, I have the sub inside now and I tried the AA battery and the cone didn't move. Do I need to try the 9v to see if it will move?
johnwohl
johnwohl
Fargo, ND
1phatclipse
    Jun 24, 2026
    Jun 24, 2026
