New setup input
dhall615
ATL
Im in process of building a new setup and wanted to get some input. -- Not sure if this is the correct section to post in...
Rockford Fosgate T1000-1bdCP
KICKER 15" L7 SERIES 1000W / 11S15L74 S15L74
JVC Arsenal KD-A95BT
box will use the SQ specs from the L7 manual PDF
This will all be in a 02 Chevy impala
Big 3 upgraded to true 4g wire
Let me know what you think...
If you are going for sq, dont buy that kicker. Honestly i wouldnt buy the kicker if you were going for spl, sql, or sq, lol. Much better can be had for the money. Do your big 3 in 0 gauge wire, use something like audio technix or knukonceptz.
Read up on this fourm and see what equipment people are running, look into american bass, fi, DC, DD, Sundown, Audioque, SSA brands like that. Audioque has a 2200 watt amp for 60 bucks less than your rockford. Gives you head room to upgrade later down the road.
I want something loud but as I have the space I was going to use the SQ box specs. I have been lurking the forums and was talking with some coworkers about the W7 SA12 / 15 and decided to go with the L7. How good is the AMP in your opinion? I was looking at a hifonics but hear that it works but isnt that great...
So u were talking about the w7 and sa12/15 and came up with a L7 ??? the people ur talking to know nuthing..and i mean nuthing...hifonics is ehh ok low budget ..and there are better amps for the money than the rf..like stated above the aq amp
The trunk is 18.6 cu ft.
I was originally talking about putting 2 12's in and my coworkers suggested going up to a single 15. The L7 has been known for high SPL/SQL and Im fine with that. I want something that will out put massive bass and not sound like sh**.
The audioque 2200 only being 60$ less... is it a better sub or on par? I dont want to upgrade this system unless I blow it or burn it up...
aq2200 is a amp ..and listen carefully L7 are garbage forget about them all together..they sound like total shlt..and blow easily
dhall615
dhall615
ATL
Sonic.
michigan born
    May 14, 2026
michigan born
    May 14, 2026
