New Setup In Car
  • 2
1) turn your amp gains down.
2) get in the car and turn the h/u up to the maximum level you will listen to it (that doesn't have any audible distortion)
3) leave the deck at this level and go back and slowly turn the gains up on the amp until you start hearing distortion and then turn it back until there is no distortion.
good luck!
hi,i have today tuned the amps.
i,am lost on the setup of the orion eq in dish it has L @R GAINS from they in to the line driver.the fronts sond a bit load.i do not now how to adusty the p/gold eq.
the orion nt sub box is to small.do you no what size the box should be.
regards,panikos:)
for the eq (you probably don't even need it really) but try to get a hold of a test cd or something and set everything on the eq to zero and then adjust them accordingly. if you need more treble turn up the treble if you need more mids then turn up the mids if you need more bass turn up the bass etc. (someone else could probably help you better than me but... hope i helped a little bit) as for the sub box i know nothing about orion subs.
I hope this help, but in my car, i had this issue because it was picking up a signal from the head light (bulb), so I moved the cross overs to...
4
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
658
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
964
panikos
panikos
london.gb
Fuel37
winkychevelle
    May 24, 2024
