New Mids Purchased - PRV 5MR450-NDY-4
But they move your pants legs? I'm just confused as to which servers you recommend for a 2 way. I ordered the neo pro v3s and I'm getting recones for the mb8s. I'm pretty sure my dumb coworker kept kicking it and fucked it up
READ POST NUMBER 5 AGAIN.... lmao that literally went over your head.
In another thread we where talking about midbass. You said they had killer midbass here you say they have no xmax. I looked and NONE OF THEM will have good midbass
I dont think I ever stated that they have killer midbass ever....
the 6.5s have enough midbass for most people depending on the install and can reach down to 63hz in a speaker cabinet and around 70hz in an IB install in a door with lower power, but compared do their output levels everywhere else, midbass is definitely not the star of the show but its there. Thats why I've made that clear on almost all my posts on them I recommend them as a dedicated mid, especially if you are going down on cone area, However their midbass is definitely A LOT better than all the cheaper PA mids.
Idk I just took from your post when you say killer mids from an 8 I thinking great midbass.
The b&ks I have are almost a subwoofer. With 300 I could cross the at 50. I have um 450 they simply can take that much that low but still crossed at 70 they straight up got down. I mean 1w5hz was enought to move arm hair..I'm hoping the sundown s with the higher qes are better suited to ib. If not I'm build a custo. Door panel and do ported.
I'm trying to to modify the doors to much because I do t want to get put in extreme and go aginst trailer cars.
Idk I just took from your post when you say killer mids from an 8 I thinking great midbass. The b&ks I have are almost a subwoofer. With 300 I could cross the at 50. I have um 450 they simply can take that much that low but still crossed at 70 they straight up got down. I mean 1w5hz was enought to move arm hair..I'm hoping the sundown s with the higher qes are better suited to ib. If not I'm build a custo. Door panel and do ported.
Yeah we get the same sh*t with the crescendo pwxs. I can just turn filters off directly and go hard without it smelling down to 28hz easy.
This alone is a testomonial of just the 8s... Imagine two 10s.
Can't speak to the Orions. I had a decent set of JBLs which sounded great...or so I thought. lol These 5s are impressive, and the PWX 8s really do an impressive job. I've got leaky doors due to the design from the factory. The door panel doesn't pop on or bolt in. It slides down into channels, so when the panel is actually on, there are six 1" x 2" channels still wide open which I have yet to figure out how to seal. The doors have CLD, CCF, MLV, 1" thick fiberglass ceiling tiles sealed in plastic, 3/8" MDF filling the large holes in the door using butyl rubber sealant, and I have open cell foam behind the speakers in my homemade door pod (the PRV location is sealed and the PWX is vented into the door cavity). With the sub turned off via the HU (but 8s still crossed over at 80Hz with a 12dB slope) I get more bass than any factory system I've heard, even when they had subwoofers. Beats even the 8" subs I had installed in the doors until I could get these bought. lol Yes, I was desperate.
I'm gonna call bullshit. No shorting ring nothing special. Just a 10$ speaker with a fancy name
Fine. Ill have a video up by tonight or tomorrow, 10 dollar speaker fks up most of every midbass from every component set out there. Ive tried a lot. None can compare and im talking about 6.5 to 6.5 comparisons. The 8s and 10s are on another level.
My sundown neos pro come today slice. If they are better than the b&ks. I'm ****. I doubt they are though it looks like they have alot short coil as and probably 4mm xmax tops..
Sguirrelfeather
Sguirrelfeather
Mountain Home, ID
Papermaker85
