New Mach 5 Build - Zero Power Compression
Is the goal SQ or SPL? Also, it is impossible to eliminate power compression, current running through a resistive element creates heat, always. Thus that coil will still heat and power compression will occur, it just maybe lower than most.
I would guess a coil that size should be able to handle on the order of 6kw //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
I want to see the motor that thing is going in to !
inherit problem of larger coils is more moving mass. I don't know how you're going to solve that slight issue unless you make the cone out of kleenex //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
All you need to overcome that though is enough motor strength.
Reminds me of some antenna loading coils I've used //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well of course I was stretching the reality of it with my statement //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I would hope by now you'd know better //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Yeah, they were pretty sweet. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The difference with mine is it won't have a basket. This was something I was working on a number of months ago but ended up throwing in the corner to set up the assembly line.
Now with a big lathe on the way, its time to come back to this.
m
mrogowski
Beware the eyes of Johnny
mrogowski
Winnipeg
mrogowski
