Sorry to keep posting. I am at a loss. I recently installed an external amplifier, wires, and speakers. I installed a headunit, RCAs, and the remote wire in January. The headunit has performed flawlessly. After installing the amplifier, I had an issue where my mid drivers were not playing. After measuring the resistance I determined that it was a short caused by the speaker terminals making contact with my aluminum soundproofing. I rotated the speakers so this was no longer the case. The system sounds much better, but there are three new issues:
One: At random, all sound to my speakers will stop and then resume one second later. It isn't related to bumps or turns. The only consistency that I can find is that it will not occur within the first 20 minutes of driving and it doesn't seem to occur less than 20/50 volume (gain set around 50%). To put this volume in perspective, it is about as loud as a conversation. So it might be tied to volume, but it doesn't need to be loud. The sound seems to cut out at random. Sometimes it doesn't happen for 4 hours of driving; sometime it happens twice in 30 minutes. The amp feels warm to the touch, but not hot. I improved the ground as first diagnosis indicated this might be the problem. I measured all of the resistances and the ground. Someone recommended that I test the voltage and ground with the amp on. If someone could elaborate on how to do this, it would be appreciated:
Front left tweeter:3.8 ohm
Front left mid driver: 3.5 ohm
Front right tweeter: 3.5 ohm
Front right mid driver: 3.4 ohm
At the amp:
front left: 3.8 ohm
Front right: 3.7 ohm
Rear left: 4 ohm
Rear right: 4 ohm
Ground test (one pole in power wire and one pole in ground wire): 12.33 V
This plays into my second issue: The right front speaker is louder than the left front. The tweeter and the mid driver are both louder on the right front. I would say that it is 15-20% louder. I want to get a second opinion to make sure I’m just not a little deaf in one ear, but I can feel the mids are stronger from the right. I would think that the measured resistance indicates that something is wrong. Could someone guess as to what (or give me a test?) I may have to rotate my speakers again, I just hate doing it since my spacers have 4 extra sets of holes already and I would hate to have them looking like pincushions (took a lot of time and effort to fabricate those things).
Third issue: My FM radio signal is weaker. The HD stations have little to no static by the city, but even those lose signal (ie static) at locations they didn’t use to. The non HD channels have static most places (not in prime signal locations). Is this normal behavior? Does the deck amp have some sort of signal boost that is lost when I switch to an external amplifier? I should mention it is a cheap ($150) 5 channel amplifier (with good reviews). This isn’t the biggest deal, but I wonder if it is an installation issue causing issues elsewhere.
Any help is appreciated! I figure my first test will be to swap the two front RCAs with each other to verify the cable isn’t the problem.
At the amp:
front left: 3.8 ohm
Rear left: 4 ohm
Rear right: 4 ohm
