keep_hope_alive
Premium Member
Acoustics Engineer
I'll have to give that a try this weekend. Could I just strip the + and - speaker wires, twist them together and attach and RCA plug to them to attach to the head unit?
no. positive to RCA center pin. negative to RCA shield. for each speaker output. start with just the fronts and use your fader to compare.
---------- Post added at 02:01 PM ---------- Previous post was at 02:00 PM ----------
no. a voltage regulator is not a signal-level device. you may be using the wrong term - maybe you think of a LOC? a LOC would work.couldn't he just wire in a voltage regulator before the amp? i would think this would be the easiest possible solution and the easiest to reverse should he ever need to go back to stock. i may be a ******* though.
