Ok guys I have a quick question. I have just installed a second amp in my car to run a set of components. I have a 30 Amp fuse at the battery and then a distrobution box with two 60 Amp fuses supplying each amp. The problem is when I turned it all on everyting worked until I turned up the volume and then the fuse at the battery blew. Now my amp insatll instructions say that both amps require a 60 Amp fuse. A friend tells me to check my wiring because the fuse should not have blown. But I think it just blew because that amps can draw as much as 60 Amps. So if I replace the fuse with a 60 Amp will it be ok???
Oh by the way I have 4ga from the battery to the distro block and then 8ga to the amps.
One amp is a 750 watt 4 chan and the other is an 800 watt 2 chan. Thanks all.
