New Amp Install
MPNX2
CA
Ok guys I have a quick question. I have just installed a second amp in my car to run a set of components. I have a 30 Amp fuse at the battery and then a distrobution box with two 60 Amp fuses supplying each amp. The problem is when I turned it all on everyting worked until I turned up the volume and then the fuse at the battery blew. Now my amp insatll instructions say that both amps require a 60 Amp fuse. A friend tells me to check my wiring because the fuse should not have blown. But I think it just blew because that amps can draw as much as 60 Amps. So if I replace the fuse with a 60 Amp will it be ok???
Oh by the way I have 4ga from the battery to the distro block and then 8ga to the amps.
One amp is a 750 watt 4 chan and the other is an 800 watt 2 chan. Thanks all.
ok...lets see...this is what you do....you have to add up all the fuses after the distro block. you said you have two 60 amp fuses. that would be 120 amps. think about it. you cant get 120 amps through a 30 amp fuse. therefor you need a 120 amp fuse at the battery
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
990
MPNX2
MPNX2
CA
fantomas
