neon string help plz
There is 2 wires going into the head lamp in the trunk. A pink wire going to the switch that turns it on and a brown and white wire that goes to the ignition illumination. Do i put one wire to each of them or one wire to the pink and one wire to the ground?
If you tap into the power feed for the trunk light then the only time that stringlight will operate is when the trunklid is open. If that's what you're wanting then disregard this post but I got the impression you were wanting that light to be on at other times?
If I'm mistaken then again, disregard this post...
If you tap into the power feed for the trunk light then the only time that stringlight will operate is when the trunklid is open. If that's what you're wanting then disregard this post but I got the impression you were wanting that light to be on at other times?If I'm mistaken then again, disregard this post...
why would you want the light on when the trunk is closed? you're silly prowler //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
My assumption (and resultant disclaimer in case I was wrong) was that he wanted the stringlight to be working while he was driving around listening to his setup rather than only when the trunklid was up.
If the end purpose is purely to illuminate the trunk interior when it is open then my post is immaterial. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
RollinRemz05
RollinRemz05
Toms River, NJ
Prowler573
