wiring neons
is there a way to hook up neon lights to flash when the bass hits like who them to sub amp or do u need the special neons to do that
If this is what you're after then just go to Auto Zone or Pep Boys or wherever is most handy to you as far as auto parts goes and just buy the neon lightsticks that have the music sensor built in. Give it power and ground (or simply use the supplied cigarette lighter-plug if you're not overly concerned about having wires exposed in your vehicle) and you're gold.
i dont really care if they flash or not i just found one layin round my house so i thought why not
when wiring it could i just use my ground for my amps and my turn on lead?
Yes, but remember that the remote accessory activation output from your HU averages less than .5mA and consequently isn't designed to turn-on an excess of items.
If your setup includes more than 2 items that you're going to want activated by your head unit then you'll likely want to incorporate a relay to take over remote turn-on duties. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
right now i have a kicker 350x4 and a rockford 750s
so its already turnin on 2 amps so u suggest a relay
where can i get ones of these / price
Im also looking into neon light, just for looks right above the box... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have one blue neon rod in the car that sits on the flat part (the bit behind your legs if you were sitting in the backseat) of the rear seat riser and one in the trunk.
Running a $5 relay > burning the remote accessory activation output out of your HU //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i used to have one...got them in LA but i gave to a friend and now i couldnt find it again in LA . I don tnow the brand let me check and let u guy know. it can be turn on constantly or just turn on for the beat..
Im getting a set of the 12" cathodes from there. Im going to wire them to the power wire for the trunk light, so when i opn the trunk, they come on. If you dont want to get a relay, you can do that.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The OP:
Your way certainly works, esp...but not for this purpose. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Reit38
Total MindFawk
Reit38
IA
wesl56
