Need wiring Help
  • 4
i got a rockford t1500 and i want to run all 3 subs off this amp and i dont know if you can and if you can i dont know how to wire it thanks
That's a no no ! All 3 subs have to be identical.
ok thats what i thought too i was just seeing if it was possible. The only way to run them all on the same amp would to have a 4 channel amp right?
A four channel amp is meant to either
1) Run speakers, or
2) Run a pair of subs on mediocre wattage (generally speaking, and around
3) Run a pair of speakers & a sub (again, usually
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
385
Brandon9
Brandon9
michigan
sjv13
    May 20, 2024
    May 20, 2024
