need to hide my subs
chopstick1981
I need to hide my subs. i have a fiberglass box built to the tire well. as it is right now i have a carpeted board i put on top when im not using the subs to give the appearance of a false trunk floor, but that is turning into a pain in the *** cuz i have to remove it every time i listen to music. has anyone ever seen a mesh grill of some sort covering a sub, i thought that might conceal and let me use them at the same time. Any one have any good ideas to allow me to conceal the subs and use them at the same time???
Just use some regular screen material from Home Depot/ Lowes. You may even be able to find some at Walmart.
Lay it on top of the wood and you should be able to lay the carpet on top of that (assuming the carpet has no rubber backing). If one layer of the screen it too week, two layers should be good. Also, instead of cutting holes the size of your subs, you can just cut multiple small holes if there's a little buffer area between the subs and this panel.
I hope this helps.
chopstick1981
chopstick1981
Vancouver, WA
DirtySchemer
